Ohm_slaw
10 µW
I am trying to get a Bafang G062 1000W motor through the autotune procedure for the PhaseRunner. I keep getting “instantaneous under voltage.”
I blame the bench power supply that I am using. The test passes when I use the bike’s own battery. My inline DC power meter says that the test pulls 8A with the battery. However - the bench power supply is rated to 10A and it won’t run. ???
Is the power supply crap? Does anyone here run larger motors with a bench power supply?
I had thought about wiring in some capacitors but that adds some cost. It’s also a little dangerous.
Suggestions? I would like something that will run motors on the bench without having to splice into the bike’s battery.
