If you were going to build a large battery for a car in the 8-10KW size, what would you use? Assuming you wanted to make this not so costly. Also size is of a concern as there is not much room to put the battery in.
Specs for the battery would be around 160volts, with at least 100 amp charge for regenerative braking, this is for a hybrid car battery conversion.
I've heard Leaf cells recommended, but wondering what you would consider using. Maybe one of the 18650 cells?
Thanks.
Thanks.
