powersupply
I try to identify the parameters needed to match twelve 4s1p packs arranged as 12s4p.
The goal is to match these packs in the most optimal way so that the (4xparalleled) cell capacities of each of the 12 (serial) stacks are as equal throught the stack as possible.
How that is done is another topic and I will address that later, an Excel/VB implementaion is in the works, so PLEASE do not get into the how and so on for now.
Right now, I only need to find out which parameters (volts/internal resistance/heat?) identify each cells capacity/capabillity.
And if voltage would be sufficient in the descirbed scneario.
For instance:
I have 12x 4s1p 5Ah packs from hobbyking arranged as 12s4p.
http://www.hobbyking.com/hobbyking/store/__18631__Turnigy_5000mAh_4S1P_14_8v_20C_hardcase_pack_USA_Warehouse_.html
Did follow recomendations (as far as I had the equipment) breaking them in with light load and charging them slowly, three times.
Then used them 3 times on my 750W scooter, discharging them down to 3.6V or higher.
Then put ALL packs in parallel (4s12p) and charged them to 16.4V (4.1V).
Their balance wires were connected to each other during both discharge and charge (on cell level).
Then used them 2 times without their balance wires connected to each other and noticed some larger differences (up to 100mV), prompting me to slowly adjust them to each other before paralleling them ALL and charging them to 16.4V, like above (their balance wires were connected to each other during charge only).
After his, I used them twice (down to 3.507V for the lowest), and charged them as they were (12s4p) with a 48V CC/CV charger (the original SLA charger modded to 48V). These two times, their balance wires were not connected to each other during both discharge and charge.
Measured their (cell) voltages and found even larger discrepancies between them as expected.
Now I wonder, is the residual cell voltage good enough to identify the cells capacity?
I mean their voltages do represent their charge amount after the discharge, right?
Giving an indication how much capacity that particular cell had in relation to other cells?
Equipment I have are one CellLog and an older Fluke DMM (while the CellLog has a higher resolution than the Fluke).
Thanks!!!
For instance:
Thanks!!!
