BTW, since this is a good discussion on these wheels/tires:
I'm considering a new trike build, based on SB Cruiser, still with no suspension, but using much larger diameter wheels to provide a better ride over the mildly bad road sections we have, vs the 20" (22" actual diameter) rear wheels Im using now.
The 26" front wheel with about 2.5" (CST City) tire on the front has been fine, for the most part, but the rear end houses the dog(s) or cargo, up to 350lbs+. So with the small wheels, and a load, it's a harsh ride.
Adding suspension is complicated and heavy and takes too much space away from the cargo area, or else raises up the cargo bed higher, depending on the design, so larger wheels to roll over stuff easier seems a simpler and better approach.
More air volume should give better suspension in this situation, AFAIK. So...the Origin8 Supercell, based on it's pedicab usage, should work well enough. The only worry I would have would be flat resistance, against standard road debris (particularly short nails, mesquite thorns, goatheads, broken glass, steel-belted-tire wire bits, and broken plastics from car bodies. (generally I am unable to avoid any of these when riding in traffic, as there isnt' anywhere for me to go)
Then, rims suitable for this type of usage scenario. I'm likely to keep using large hubmotors in the rear wheels, for simplicity, but if I could find a reliable cheap peerless differential that I could adapt to using on the trike, and other suitable components to put something like a QS205 as a reliable middrive, I'd consider using "regular" (pedicab) wheels instead.
