JackFlorey
Not to reopen this long debate; I just had one question. Assuming a motor wired for delta (and with Hall sensors positioned for delta operation) what changes in sensor position would you have to make to the sensors if you reconnect the motor for wye operation?
Also, would it be safe to assume that a controller like the Phaserunner doesn't care; that during learning it will figure out what the phasing/offset for the Hall sensors are without caring about whether it's wye or delta?
(OK that was two questions.)
