#ZALOMOTO - Light Electric Motorcycle 12kW QS
ZALO
A motorcycle built as a test of my skills.
Designed entirely by me and built in my free time after work.
Designed for off-road riding and forest paths.
Technical specifications:
QS 205 V3 3000W 5T winding, hubsink
20S14P VTC5 BMS 300A battery
Sabvoton 72150 controller
Initially, the Mxus 3k Turbo was assembled, but I missed the torque that lifts the front wheel.
Then I installed the qs205 V3 5T motor, currently the sabvoton is set to max.
So the power consumed from the battery does not exceed 13kW.
The construction of #ZALOMOTO gave me a lot of experience, it gives a lot of emotions while driving.
However, I notice a lot of design flaws with a hub motor.
I am at the stage of designing another motorcycle,
a completely different one with a mid drive.
Nice bike, especially for a first build from scratch. How much does she weigh? Performance specs? Got more pics of the guts?
Looks amazing dude.
What do you hope to change moving to middrive?
Sent from my CLT-L09 using Tapatalk
@John in Cr,
weight around 60kg, the range of this type of motorcycle is 50-200KM, of course it depends on how much I use the throttle and hold the front wheel up :D
@Hickbeard,
I design another construction with a tubular frame, with a centrally located motor, for better weight distribution (I see the disadvantages of the hub motor in off-road).
This construction is really great but for light terrain and higher speeds.
I expect even more power from my next project.
Some detailed photos during construction:
- 2x 10s14p li-ion Sony VTC5a
-parts fresh after powder coating, great structure
-inside, sabvoton 72150 and solidly installed li-ion packs
Hi,
What are those cell holder that you are using ?
They look really nice.
Thanks, those looks way better than the classic square one but i can't find completly modulare one like yours, only premade 4s or more.
Can you ride on public road with your bike ?
I usually drive off public roads.
If I were to treat it as a motorcycle, I would have to homologation certificate.
