zombiess
The height should be adjustable by playing with the shock length. I have a 240mm shock installed and have it set to compress about 25% with my full weight on the bike.
A shock that is shorter will cause a more slack angle and lengthen the wheel base some, but these DNM forks are setup for downhill so they are long. A shorter fork with less travel combined with a shorter rear shock could be setup for a shorter person. I might try this if I build one for my wife, not sure if that will be possible though since she is 5' 0 and this frame is a large.
The Schlumpf takes standard square peg arms as far as I can tell. Doesn't appear to be anything special about them.
For the Aussies interested in the frame sets, contact zak@madmanebikes.com he is the Australian dealer
