Ugrd said:Been busy with some work but I got time to finally post my 17x2.25 and 17x2.50 rims and tires on my V2100, spraypainted black with red lines
Rix said:Ugrd said:Been busy with some work but I got time to finally post my 17x2.25 and 17x2.50 rims and tires on my V2100, spraypainted black with red lines
Looks like a wheeling machine!
Jackrabbit said:Wheels all built up. Will collect them tomorrow and complete my build. 19x1.85 Excel rims, V3 Cromotor and Ethirteen front hub.
voicecoils said:Jackrabbit said:Wheels all built up. Will collect them tomorrow and complete my build. 19x1.85 Excel rims, V3 Cromotor and Ethirteen front hub.
Beautiful build.
Looks like the wheelbuilder drilled out those Excel rims at just the right angles for lacing 2 cross front and rear. Both look to have great alignment from spoke to nipple & that doesn't happen by accident!
Rix said:voicecoils said:Jackrabbit said:Wheels all built up. Will collect them tomorrow and complete my build. 19x1.85 Excel rims, V3 Cromotor and Ethirteen front hub.
Beautiful build.
I missed that Abe, that is a 2X lace job, beautiful. One of yours?
unclejam said:Looks serious. Is that a Raptor frame?
Jackrabbit said:unclejam said:Looks serious. Is that a Raptor frame?
Yes, it's a Raptor. I'm not sure how I'm going to pass it off as a bicycle when the inevitable police stop happens. It looks a little more serious than I'd anticipated.
richdeloup said:19x1.85 Excel rims, V3 Cromotor and Ethirteen front hub.
Def a nice look to them with 2x. What spoke size and nipples were used to fit those Excel nipple holes, did you need washers?
Jackrabbit said:richdeloup said:19x1.85 Excel rims, V3 Cromotor and Ethirteen front hub.
The front are 12g and the rear are 10g. The rims were custom drilled for the motor and front hub. The guy who built them usually builds motocross & supermoto wheels. I'm not sure what size nipples he used but there are no washers.
Offroader said:Does anyone have the issue when installing the tire the tube gets caught between the tire in the rim right above the valve stem? I guess because the valve stem flattens the tube in that area it gets caught easily between the tire and the rim. It must catch a very small amount but enough to make me think that if I drive like this it may damage the tube. If I release the air and push the tire in that area I can see the tip of the tube, but it is very difficult to get the tube completely inside the tire.
It happens to me almost every time I mount my tire so I assume it is a common problem, it is not so easy to spot unless you look for it and you will notice that the tire is slightly higher in that area after filling the tire with air. If you are not looking you would not notice and the tube would stay pinched there. I'm not sure if it would be an issue, but it may not be.
It is a bit of a pain to free the tube and I usually spend 5-10 minutes messing around with it, What I found works best is to let the air out and push the valve stem up all the way and then keep trying to refill it. Pushing the valve stem up must free the tube between the tire and rim, but it doesn't work every time.
I was wondering if someone has an easier solution to free the tube and has also noticed this problem?
just make sure you have some sturdy riding gloves, a good nerve and knoledge of ped paths in the local area and you have a fighting chance :lol:unclejam said:Jackrabbit said:unclejam said:Looks serious. Is that a Raptor frame?
My plan is simple: Don't actually stop! :wink:
voicecoils said:I would like to find some moto rims that suit 2 cross on big hubmotors without extra drilling. Strength+reliability should be at least as good if not better and 2 cross has a nice visual appeal to me.
johnrobholmes said:I haven't found a rim maker with good extrusions that can handle the larger angles. Either they specialize in much heavier rims and can handle 25+ degree holes, or they specialize in medium to light weight rims and are limited at 18 to 20 degrees. So far we haven't had an issue with single cross on 17s or 19s with 12 to 10g spokes.voicecoils said:I would like to find some moto rims that suit 2 cross on big hubmotors without extra drilling. Strength+reliability should be at least as good if not better and 2 cross has a nice visual appeal to me.
ridethelightning said:unclejam said:just make sure you have some sturdy riding gloves, a good nerve and knoledge of ped paths in the local area and you have a fighting chance :lol:Jackrabbit said:Yes, it's a Raptor. I'm not sure how I'm going to pass it off as a bicycle when the inevitable police stop happens. It looks a little more serious than I'd anticipated.
that black raptor looks deadly serious. be careful.
[/quote]just make sure you have some sturdy riding gloves, a good nerve and knoledge of ped paths in the local area and you have a fighting chance :lol:
