teslanv said:
Most people want the wider rims so they can run fatter tires.
I have looked into getting these rims for the MXUS motors, and to special order a specific size with the spoke holes drilled at the proper angle you need a minimum order of 50 rims.
teslanv, I run probably one of the fattest tires here a shinko 3" 241 which I love. Most people I think here run shinko 241 at 19x2.75 which isn't nearly as fat. I don't think it would be an issue running with a 1.4".
I have to figure out just how important the rim width is for optimal tire performance. I know the tire will be a bit more rounded when using a narrower rim. I'm going to think that since straight line traction isn't an issue for an ebike, having more contact patch with the ground doesn't matter at all. Maybe even a bit rounded at the top with less contact patch to the ground isn't actually a bad thing for an ebike.
If you look at bicycles, they have skinny tires in the rear. This is because straight line traction isn't a problem because there is no 50HP motor on the bike. So it would seem that narrow tires actually offer better traction from side to side while the fatter tires just flat and don't dig in. However, I do like the fat 3" shinko in the rear to help cushion the heavy rear of my bike, this doesn't make it necessary to have the tire have full contact with the ground which makes wider rims unnecessary in my opinion.
I believe Rix even mentioned that the 1.6" was unnecessary in his opinion and always recommended the 1.4".
