Vanilla ice,
Thanks for the info. Just for clarity, your'e saying the 24V MY1018Z spins 2750 rpm at 24V, drawing 13.3 amps (no load?) and the 36V MY1018Z spins the same 2750 rpm at 36V, drawing 8.9 amps (no load?), is that correct? Note that between the two, they show the same gear ratio. Refer to the two 250 watt MY1018Z models below, they both look identical to the motor in this thread. The other 2 motors, like you say (24V MY1016Z3 and 36V MY1020Z3), are completely different .
250W GEARED Motor - 24 Volts (Model: MY1018Z)
Motor Parts - 106105
Shipping Weight: 5.5 lbs.
MY1018Z 24 Volt, 250 Watt, 2750 RPM, 13.3 Amp, permanent-magnet motor.
• 9 tooth sprocket for #35 chain.
• 12 gauge power leads
• Gear Ratio: 79:11 (7.182)
350W GEARED Motor - 24 Volts (Model: MY1016Z3)
Motor Parts - 106115
Shipping Weight: 9.0 lbs.
MY1016Z3 24 Volt, 350 Watt, 3300 RPM, 19.2 Amp, permanent-magnet motor.
• 12 gauge power leads.
• Gear Ratio: 88:9 (9.778)
250W GEARED Motor - 36 Volts (Model: MY1018Z)
Motor Parts - 106124
MY1018Z 36 Volt, 250 Watt, 2750 RPM, 8.9 Amp, permanent-magnet motor.
600W GEARED Motor - 36 Volts (Model: MY1020Z3)
Motor Parts - 106155
Shipping Weight: 14.0 lbs.
MY1020Z3 36 Volt, 600 Watt, 3200 RPM, 21.4 Amp, permanent-magnet motor.
• 9 tooth sprocket for #40 and #420 chains.
• Gear Ratio: 60:9 (6.67)
