numberonebikeslover
fechter said:Just make sure each commutator segment has a connection.
If you have a short between strands in a winding, it will be hard to detect by measuring resistance. A shorted turn will act like a shorted secondary in a transformer and result in excessive heat and current draw. Once you get it all back together, run the motor with no load and measure the current. Hopefully it will be close to what it was originally. This is the best test.
Also measure resistance between the commutator segments and the motor shaft. There should be no continuity there (infinite ohms). If the insulation of the wire gets cut on the edge of the iron, it can short out.
The commutator gets very hot during normal operation. I'm not sure what the temperature rating of super glue is, but it could fail at high temperatures. Winding some thread around the segments is not a bad idea, just use something with a high temperature rating. Nomex or Kevlar are the best, silk is also excellent. Polyester is not good. Cotton is between.
Sir, It is always a great deal of learning from your comment and therefore, I await it desperately. Thank you very much for the time you take to read my posting and then take precious time out of your busy life and post a comment.
Yes I have tested; every commutator segment has a connection. Last time it was very painstaking for me to open the assembled motor and found out that one segment was not connected. So I learned this lesson the hard way.
I am sure that there will be no sort between winded strands for this very reason I bought the new wire and removed the old one.
No load current of the motor I will check after motor being assembled together.
The short of any wire at any point with the motor shaft; I am sure there wont be because there is plastic / ceramics insulation on entire motor and a very good one. But I will check to make sure there is no short.
This is true that commutator will get hot and only the glue wouldn't hold the poor repaired thing together. I thought it over and decided to use something which is called as (Mochi Taar) in our native language. (Mochi means Cobbler and Taar means segment). It is a kind of segment used by the cobblers to sew and mend the shoos and foot ware. It is a mixture of silk and cotton and although being thin just a single strand is not breakable with bare hands.
Thanks again. Yours Respectfully; M.Naeem Zahid
