motomech
A couple of observations;
First off, the notch in the end of the axle should be facing down. The idea is, in wet conditions, the water running down the cable will not enter. After it is repositioned, fill the opening with silicone.
Also, technically, the torque arm would be positioned in the opposite direction, pushing against the fork tube rather than pulling away from it. But, the Cute really doesn't generate enough force to cause the hose clamp to fail, so I'm sure it's fine that way.
Be sure to ck. the axle nuts, they tend to work loose, especially at the high current you are running. I Loctite them.
The OEM 9-pin wire is used on larger motors than the Cute, no need to be concerned about the current capacity. I use 4 mm bullets on the power wires, 3.5 mm bullet connectors on the phase wires and a 5-wire JXT connector for the Halls when shortening the cables.
I mount thumb throttles on the left side since the frt. chainring is never shifted with a motor. The action of pushing down the lever is very natural.
Current limiting only works in PAS.
I never solved that problem before I switched back to a square wave controller. It could be that your speed reading is from the motor only. You may need to reposition the sensor closer to the magnet. It's a finicky thing.There is a thread I started dealing with the SLCD-3 display. A search should turn it up. Most Cute models have the pole # listed in the product info @ BMS Battery.
Possibly, but with my bikes, pedal strikes in the corners are common. It's then when the throttle is useful.
I decided to replace the DC bullet connectors with some locking MC4 PV connectors. I would like to do something similar for the motor phase connectors, as I don't require anywhere near the 1m of (rather inadequate looking) cable that it came with.
All the BMS Battery wheels come that way. It really shouldn't be out of true, as it hasn't had the spokes tensioned. It's a simple matter to bring the spokes in tension.The wheel is also somewhat out of true. Perhaps I would have been better off building my own wheel.
The thumb throttle is installed on the outside of the grip. I can operate it with the edge of my hand. No room for it with the bulky combo brake/shifter. Putting it on top of the shifter might work.
The motor was only a little warm after this kind of riding, and the controller was cold. I had set what I thought was a 25A/1.25 current limit according to the parameters, but that may be operating on the $CONTROLLER_MAX-0.5*n schedule instead.
Steel gears would whine like a dentist's drill, besides, the clutch failure limit is close to the limit of the nylon gears. The S12S has enough of a "soft start" that they should be ok. When the gears are strained, you can feel it and be more easy with the throttle.Pulls over 1150W. I will have to watch the torque on the nylon gears more than anything, I would love to see what it could do with some steel gears.
Even with an external speed sensor, it isn't currently reading the speed when freewheeling. I also had to guess at the motor pole count, which is set to 12.6 * 16 poles = 208 (no spec I could find anywhere), does anyone here know?
Haven't tried the PAS yet, it may yet make the throttle redundant.
