Due to circumstances that
should have been completely within my control, I've made it into a hardtail. Specifically, I made some beautiful welds attaching the swingarm brackets to the rear bottom bracket shell--1/8" too close together. I swear I measured at least twice and welded once. Should have measured a few more times. Removing them kinda ruined that BB shell, so I moved on. I removed the suspension brackets all together and fabbed up seat and chain stays.
Yes, those are a pair of DocBass torque plates I'm using as dropouts. I had them sitting around, so why not?
And here she is after the first test run in the new configuration. The wheelbase is now 55". With the balloon tires, soft front suspension fork, and springer seat, the ride is barely noticibly stiffer. Admittedly, I did not ride far as it's 15*F right now. Warmer weather and longer rides may prove less comfy. I've added a SRAM single sprocket crankset over a Truvative powerspline BB. I'm able to sit rather upright in what would likely be called a pedal-forward configuration.
Next on the to do list... a few more tests to be sure that my welds hold up, add a chain and deraileur, rear brake caliper mount, battery bag/box (the duct tape just doesn't do it for me,) then pull it all apart for some paint.
It's not pretty. I know. But it has been a fun learning process and I'm ready to move onto my next frame project. I have the tubing to build another similar to this (perhaps getting it right, including suspension,) or a SWB recumbent. I have six sets of Atomic Zombie plans and my ruptured vertebral disc has been urging me toward recumbents lately. The mountain bike posture is quite the pain.
