Jeremy Harris
Thanks.
It's nice to know that someone else had a very similar problem with the disc brake idea. I guess I could have tried dual callipers, but I only had one spare brake in my junk pile..............
I'm hoping the eddy current brake will turn out to be smooth and easy to control. I've done a fair bit of reading up on eddy current brakes, both from web searches and from some helpful papers that Bigmoose sent me.
The motor mount has very little friction and, as you've spotted, the bearing area is pretty large. There are stops that restrict the torque arm to about 80 degrees of movement, albeit accidental ones (the securing screw interfere with each other and limit the angle the arm will turn). I powered it up this evening, with no load, and it spins OK. I just need to remember to check the motor direction carefully before applying any load.
Those home-made big dynos look seriously scary. Years ago I was asked to take a look at a problematic fault in the new engine control system for our Challenger main battle tank engine. This meant working inside an engine test cell with the engine running at full power about 2ft from my head. If you've ever been close to a 1200hp, 12 cylinder, twin turbocharged, 26 litre diesel engine going full chat you'll know all about the noise.............
Jeremy
Jeremy
