This is the 3rd controller since the bike was purchased. Since new, I have had somewhat frequent ERR1 and ERR2's, most encountered when switching from battery A to battery B. Sometimes the err's occur for no reason that I can detect. My dealer told me a long time ago that E+ had told him to use this reset procedure when the ERR's occurred. Electrically, I don't know what is taking place when I do the reset procedure, all I know is that it gets rid of the ERR's every time.
Miro said..."So basically you suggest to plug RS485 comm cable from hub battery BMS straight into display/controller?" YES, exactly.
To add, If I remember correctly, when the display is plugged into the hub comm cable and is turned on, it will boot and then settle with a ERR code. Not to worry, turn it off and re-install in the system and the original ERR's are gone and the system works normal.
On occasion, when I switch from battery A to battery B and bring up the PWR display, it will show from 25 to 250 watts being used when I am not moving or using any throttle. The bike will operate normally but it is obvious the Watts being displayed are higher than what is actually being used. This is another one of the occasions when I do the reset and all is well afterwards.
