MitchJi
Hi,
http://www.sunrise-ev.com/LeesEVs.htm#battbridge
This Batt-Bridge Battery Out-Of-Balance Alarm seems like an easy way to to check to monitor two equal series strings for a bad cell:Using the Leaf modules it would be simple to make one series string with (for example) 224S 4P (120AH). Using the Volt sub-packs the closest you could easily come to that would be to use two series strings of 24s 3P each. How much more complicated will it be to build a pack with multiple series strings (the OP is planning 2 series strings of 48S 3P).
An EV's pack consists of many cells or batteries. In theory, they are all identical. In practice, they aren't. There will always be a "weak link" somewhere in the pack. That's the cell that limits your range, and limits how much you can charge before damage begins.
But it is difficult to know if you have a weak cell. Total pack voltage won't tell you until too late. The amount of circuitry needed to monitor every single cell can get very complicated and expensive!
The Batt-Bridge is a quick-n-dirty "idiot light" to give you a good/bad warning when any cell in the pack goes undervoltage (dead) or overvoltage (overcharged). It works with all types of batteries; lead-acid, lithium, nicad, or nimh. If it lights up red, back off on the current until it goes out. If it stays on even at zero current, stop driving or charging until you find the problem and fix it!
How it works: The Batt-Bridge divides the pack in half, and compares the voltage of each half. When the two halves are equal (within 1 volt or less), a green LED is lit. If a cell goes dead or begins overcharging somewhere in the pack, its voltage typically changes by more than a volt. This imbalance lights one of two bright red LEDs to tell you which half of the pack is low.
D1 is a standard brightness green LED. D2 and D3 should be ultrabright red LEDs for best visibility. R1 and R2 should be identical resistors, chosen to provide about 10ma at your pack voltage. The current sets the sensitivity and brightness of the LEDs.
Construction: Mount the LEDs in a pilot light holder. Install it on the dashboard where the driver can easily see it, and where it won't be washed out by direct sunlight. Mount the resistors at the battery terminal ends of the wires, so they will limit the current in case of shorts.
Batt-Bridge parts kit -- $10. Includes LEDs, resistors, lamp holder, and detailed instructions. Specify pack voltage. $5 for US shipping and handling. For shipping outside the USA, email for details.
Batt-Bridge, Assembled -- $20. Assembled Batt-Bridge in panel mounted lampholder, with resistors and detailed instructions. Specify pack voltage. $5 for US shipping and handling. For shipping outside the USA, email for details.
