*Unfortunately, since day one, I've been plagued by broken spokes which I've been replacing with Sapim 14G and trying to keep the rim trued and tight, etc., but with limited success. My next major project may be to learn how to build a strong and properly dished wheel... (Advice welcome! )
We had another customer with the broken spokes problem on a rear NC kit (from Amped), and we rebuilt his wheel for him. I have a few suggestions about that (not in order of importance):
1. Make sure dishing is proper and even. This is far easier with a professional stand like the Park truing stand, but can be done other ways. If you know someone who has one of those stands, it will save you loads of time.
2. It is vital to get very even spoke tension. Not to name any names, but I have seen many different types of wheels from China, and the QC on wheel builds is highly variable. Just solving this will help a lot.
3. It looks like yours was built 1X with all elbows on the inside. I think it may be stronger to have the pulling (trailing) spokes elbows inside, and leading spokes elbows outside, with a twist where they cross, so that they are in strong physical contact. That tends to distribute the load better.
4. For my own bikes, given the choice between a thicker spoke (e.g. 12 ga) or a slightly thinner spoke that is butted (e.g. 13 to 14 ga, like the Wheelsmith DH13), I would always choose the butted. The reason is that far and away the most common breakage is at the elbow - it is the weakest point. In a straight gauge spoke, it is where all the tension accumulates. However, in a butted spoke, there is a long, straight section of spoke that is narrower, and acts like a spring. That moves the flexing away from the spoke bend and out to the straight part. For example, back in the days of my Currie USPD (w/600W BMC motor), it used an adapter plate mated directly to the spokes, and it was really hard on them. Plus, I was using that wheel on the rear of my Xtracycle, which regularly carried big loads. I kept breaking spokes. I rebuilt my wheel with DT Swiss Alpine III triple butted spokes, and a beefy rim that could take high spoke tension (Sun Mammoth), and never had another breakage. Those kind of butted spokes are used on tandems and on downhill bikes. We now do all our wheel builds with them, unless someone asks for otherwise. I think they will last longer than straight gauge 12 spokes.
5. Patience, patience, and more patience, especially if it is your first time. It is critical to bring up tension slowly and evenly.
Best of luck,
Morgan
