Rix said:
Yeah that was my call to the ebike suicide hotline :lol:
I can't give up riding all together. No matter what, I just can't. As per our previous discussions it's an essential part of my maintaining my sanity outside of work and home life.
I know I'm going to have to give up other aspects of riding though to mitigate the risks of further injury. The most obvious thing that's going to have to go is daily commuting to work. At least on the trails I'm in control in the vast majority of situations, on the road you're at the mercy of the cagers. I ride defensively of course and in 5 years of near daily riding I've "only" been hit twice but mixing it up with cars at the best of times doesn't end well for bike riders, let alone now. I probably should give the madass away too though arguably I'm safer on that than a fast pushy.
That means I'm back to regularly driving to work and my gas guzzling 300kw XR6T isn't a sensible choice so I'll need a new car.
Maybe this is the shove I finally need to switch over to the electric car conversion!
A gyro that cuts throttle eh? My 98 Sportster had a lean angle sensor in it. Basically the ignition was cut off if typed over. If you had something like that turned sideways so it worked fore and aft, that could be a possibility, even though I wouldn't have the slightest clue how to hook on up and make it work. You got a working concept model yet?
A simple throttle cut would be dead easy to make, you'd just need to fit a mercury switch to the frame that activated at the desired angle and connect it up to the a brake line.
I was thinking something more complex to essentially be an 'instant wheelie mode' - something like an arduino with a proportional output that could control the throttle signal on the CA V3 so it would cut just enough power to stop you flipping but if you kept it pinned you could ride around all day on the back wheel :lol:
Kepler said:
Hi Jay. I always have a bit of a peak at your thread every few days as there is usually something on there of interest or at least something to give me a bit of a giggle
. Was upset to hear that you hurt yourself and that the cause could be more sinister.
Thanks for the concern mate. Sorry to bum you out, I'll try to work on my downer to giggle ratio
t3sla said:
you should really try a high powered trike, I rode Allan's and loved it (way more fun)
Yeah it's on my list of things to do. The DO look like fun but I'm not sure where I could realistically ride it. They look like an even quicker way to get run over if ridden in public and wouldn't be suitable for most of the offroading I like to do.
Back to business, I've had a fellow ebike enthusiasm machine me up a sweet new axle for my crown motor. I've gone with bigger 16mm flats and with better steel too this one will be unbreakable I'm sure. If anyone else is looking for a good Aussie machinist I'll pass on his details. The construction of these crown axles is not cheap though and this took a heap of work. Unlike other types that have a channel machined down one edge these are cross drilled which makes the job a fair bit harder
