LightningRods said:
emaayan said:
stop jinxing me.
maybe putting spacers wasn't such a good idea ..
i'll need to take apart crankset, and remove the flat spacers i thought i'd need, as well as removing the spacers from that allen bolt.
Welcome to my world. The width of the BB shell and the width of the BB axle are set and beyond my control. There is a VERY limited amount of space to work with between the chainwheels and the hardware on the side of the lower sheets.
Now you know why I used carriage bolts with no washers.
well that may be a problem driver sprocket wise, as these are not only bigger but wider, i'm currently using the biggest 18T and they are driving the chain so the links are starting to collide against the mud guard, placing more spacers between the mudguard and driven sprocket will cause the crank arm to collide with the mudguard, unless i place more spacers on the crank arm and freewheel.
i went out on my first ride with metal cranks arms and pedals, they felt really weird which made sense when i discovered i put them not all aligned with each other (with square taper there's no room for error it's either 90 or 180 degrees, over here, it's much more fine)
i didn't notice any major improvement switching to the 18T so i might get back to get 15T, i might get more speed with enough "runway" but i'm not sure it's wise.
i switched the bmc to 50 amps, so now it's 2500 watts limit, this seems to make an improvement in acceleration.
however the chain is stil still getting loose [youtube]1cbHBJqReHI[/youtube]
it's not as worse as before, but the chain skipping still occurs when i start at 10 11th gear (i don't expect to start at that level , but it's a simulation of high load) i may need to pay our miller he says he can use better plastic then yours (i forgot it's name, starts with a d ,dihara.. ) at least the system is riding order , so i can bring it to him for a change. i replaced the allen bolt i placed instead of the inner carriage bolt, because i stripped it's it's threads (it didn't took an effort) and placed a hex bolt not sure i tightend enough.
but i see no alternative then to place an other bolt on the chain side, all this guessing and tightening feels wrong and relaying on side pressure, maybe it's happening only to me because i'm using an 18T driver sprocket and i'm 250 pounds on a 29er starting from 6th gear.
