Honk
- Joined
- Oct 10, 2011
- Messages
- 230
You misunderstand me. :wink:Miles said:You still haven't justified tripling the iron losses....
I didn't tripple the iron loss for fun. I just estimated three time higher no-load current
from experience as iron loss alone is not equal to full no-load loss.
Not true, Viscous bearing losses is RPM dependent and requires squared power input to overcome the drag going up by RPM.bearing said:Bearing losses at no load should be practically nothing...
I can tell you about my latest build. It's a small experimental powder core motor and it should really have
ultra low no-load losses due to the almost non existent losses of these materials.
I initially had 0.65Amp in no-load at 8000rpm. This was using a selected high quality low drag 8x19mm bearing.
When I swapped bearings to really small RC flight bearing 3x5mm the no-load dropt to 0.11amps.
This is the importance of low drag bearings.....a lot more than people considers.
