Yes, these latest results are for sine currents (q-axis current only).bearing said:Did you ever try with sinusoidal currents?
Miles said:How much heat can an outrunner 92mm in diameter, 56mm long and 1.1kg in weight, disperse continuously? No venting (sealed case).
Yes, the outer case dimensions.John in CR said:Are those the outer dimensions of the shell?
Looking at the table above, the maximum heat that I'll need to disperse continually will be about 150Watts, hopefully....Miles said:I don't want the magnets to get above 75 deg. C. Of course, they'll be rated at 120 deg. C. , or more.
Stator around 90 deg. C. max., I guess.
The simulations were all done at a constant speed of 3000rpm.Honk said:At what voltage have you calculated these efficiencies? Is it at 44.04V as stated earlier?
The parasitic torque determines the no load current. This is calculated in the Emetor simulations.Honk said:What No-Load current did you estimate as this highly determines the efficiency?
Something is strange though.....Have a look at the earlier 27T 30P analysis, e'g the 60amps row.
Input 60 amps x 48.52V = 2911W
Output is claimed as 2210W and heat loss 157W = 2367W
2911W input - 2367W used = 544W missing ????
Why are these hidden 544 watts not reported in the Emetor simulation? They can only be losses not given an account of.
That's possible.bearing said:The problem is that you used put P = U * I as input, and Emetor calculated the input as something like P(w) = (EMF1(w) + R1 * I1(w)) * I1(w) + (EMF2(w + 120°) ... and so on, where EMF(w) is the waveform of a phase without connection to other phases. At least, that's what I think.
If you know that, then you should also understand that using a simple constant no load current will not be very accurate, compared to reality or the output of an advanced simulation program like Emetor or FEMM.Honk said:That's possible.bearing said:The problem is that you used put P = U * I as input, and Emetor calculated the input as something like P(w) = (EMF1(w) + R1 * I1(w)) * I1(w) + (EMF2(w + 120°) ... and so on, where EMF(w) is the waveform of a phase without connection to other phases. At least, that's what I think.
The losses in all motors consist of a few well known factors.
Eddy currents and Hysteresis losses, Bearing and other drag losses, and of course I2R losses.
All of these losses except I2R is shown as the No-Load current at free RPM.
It peaks at its highest level at free RPM without any shaft load.
Loading the motor decreases No-Load as the RPM goes down.
Mainly I2R losses goes up at load due to increasing currents.
I guess we will have to wait som some "real world tests" as any simulation is 100% dependent on correct parameters.
