wesnewell
This is the MXUS 3000 V1, with 45 mm stator, so the motor is a little wider than most I would assume. IIRC it requires 142mm dropouts minimum with a 220mm axle. With the rear wheel off, the rear dropouts on the Dolomite were 205mm, but can be squeezed in considerably. When I mounted the motor I pulled them together enough to hve a couple of threads beyond the end of the axle nut and screwed the jamnuts out to there before tightening them. Not a problem except for the disc brake caliper, which I moved in to match up to the disc using longer mount bolts and washers. A single solid block would have been better for this, but I don't think the washers on each bolt will cause a problem.
