beast775
Sweet battery build. looks awesome! bike is ggggreat.
melodious said:
I've had 2x catastrophic failures at the bottom of the red portion of the Klickfix mechanism where it simply snaps and breaks off leaving whatever bag attachment to fall off . I sincerely hope it's a DIY mount vs. a Klickfix
FWIW, I wasn't even going near the speeds that you probably are going on this build and I was below the rated weight they were meant to hold. I would change those out and replace them with a metal.ambroseliao said:melodious said:
According to this picture, it's based on the KlickFix mechanism which is why I asked!
http://imageshack.us/a/img826/7784/lvae.jpg
I have the TC100 Motor, if you want to do a new build, I will give you some informations!madin88 said:The last thing was the Motor and Rims. Wanted to wait for more infos on cystalyte the Crown TC 80/100 but not much experiences comning so i decided to order Cromotor and im very glad about it.
Good choice! I have the TC100 with 26" wheel and I think it's better with 20" wheel.madin88 said:The wheels are double wall cross lacing 20" BMX rims with 2,5 / 16" Moped tires...
I don't like this You made lot of beautifull aluminium parts. I think you can do a better integration of the battery. :wink:madin88 said:Battery is mounted on the fork in peli 1300 case and its removeable.
What is the discharge rate? 10C, 20C or more?madin88 said:- 22s9p Sony Konion VTC4, charge with 8A to 90V (4,1v per cell), No balancing needed (the data sheet calaims so)
Only 60 A with 18 FET... I have 48A with 12 FET.madin88 said:- Lyen IRFB 4110 18 FET EB 318 controller currently set to 100A phase and 60A battery (its about 5kw)
I ride 23km a day for 40minutes. My average speed is 33kph. I set a speed limit of 40kph. No current limit (48A max for my controler). My consumption is about 22Wh/Km. I'm looking for some information to know if the efficiency of my system is good or not.madin88 said:range: about 60km at 25-30 Wh/km with full speed and about 200km on 33% controller speedlimit (20km/h).
Alan B said:Variable regen would be better, eventually we'll have controllers with that.
ambroseliao said:Can you post some pics of how the battery mounts to the bike? I see the KlickFix mounts attached to the fork but don't see the corresponding mount on the back of the Pelican 1300 case. It looks terrific.
John in CR said:Where are the protective insulating rings for the button ends of those cells? Manufacturers have gone to paper or plastic rings to prevent the tabs from shorting at the corner of the cells. Having positive and negative separated by only that paper thin fragile green plastic is high risk.
Did you harvest the cells by recycling used tool packs or were you able to source new Konion cells?
Great build despite my questions regarding the battery.
John
trevc2 said:What's the name of that tubing you've used to enclose your wires? It's commonly found in hardware stores, but I was looking to order a larger roll online.
dotrick said:I have the TC100 Motor, if you want to do a new build, I will give you some informations!
Nice dashboard! I like your aluminium parts! My next buil will be a CNC! To do lot of beautiful aluminium parts...
Emoto said:Hey Madin88 have you seen kiwi's method might give you some idea's http://endless-sphere.com/forums/viewtopic.php?t=33767
madin88 said:dotrick said:I have the TC100 Motor, if you want to do a new build, I will give you some informations!
-what kV does this motor have?
- is the stuttering issue above 70-80V still present?
do you have a thread of your build with TC100 motor?
The secret is the management of the temperature...madin88 said:my controller isnt modded for so far (all stock cable etc) and i dont want to blow up something^^
dotrick said:The secret is the management of the temperature...madin88 said:my controller isnt modded for so far (all stock cable etc) and i dont want to blow up something^^
melodious said:I've had 2x catastrophic failures at the bottom of the red portion of the Klickfix mechanism where it simply snaps and breaks off leaving whatever bag attachment to fall off . I sincerely hope it's a DIY mount vs. a Klickfix
madin88 said:melodious said:I've had 2x catastrophic failures at the bottom of the red portion of the Klickfix mechanism where it simply snaps and breaks off leaving whatever bag attachment to fall off . I sincerely hope it's a DIY mount vs. a Klickfix
do you mean the red clip which failured or something from the black plastic part?
You should think of that klickfix baskets have a long lever which produces torque to the mechanism. On my mechanism this is not the case because of the alu on bottom screwed in the fork tube...
madin88 said:Emoto said:Hey Madin88 have you seen kiwi's method might give you some idea's http://endless-sphere.com/forums/viewtopic.php?t=33767
..this also looks good, but i dont like the belts (i think my peli case will waggle alot on there).
I decided to stay with the Klickfix. If something will become loose, i will directly mount the case to the alu plate on the fork. the removeable battery is not an absoulutley must have for me (mostly i charge the battery left on the bike).
Emoto said:My point was more along the lines of the clamps used [ scroll down in the link i gave] just in case the klickfix fail , if you decide to give them a go.... i think there is a link in his thread for those., good luck.
madin88 said:I decided to stay with the Klickfix. If something will become loose, i will directly mount the case to the alu plate on the fork.
