samoloh
I see no problem with the design as long as there will be no balancing issues, I hope u took into consideration that when you move the controller to middle of the frame the peli cases will be lower than they are in the pictures
samoloh said:I hope u took into consideration that when you move the controller to middle of the frame the peli cases will be lower than they are in the pictures
dotrick said:
This week I wanted to modify my controler 12FET... I want to decrease the Rshunt value to increase the current... I think I'm going fishing instead!
How much did you pay your fork? I want to change mine...
madin88 said:These Infineon Controllers are so bad jerky and very uncomfortable. The only good thing is they are cheap, open source and easy to mod (if it doesnt blow up after it haha).
madin88 said:... i wish i better had taken one with dual disc brake option...
dotrick said:I don't know if it's the configuration of my CA, the controler, the TC100, the battery voltage, but for me it is the same thing... Not very confortable at low speed (under 35kph). Between 55 and 75kph it's OK.
It's an open source? I would like to see! It's easier to modify the code source than the Rshunt value!
Dual disc brake option is a good solution... Now I have one disc (very cheap) And it's not serious for the speed of my ebike!
madin88 said:I'm now in to order a Adaptto Max-E controller set.
briangv99 said:hi, I'm trying to get an adapt to max-e too for my cromotor, but no luck finding them. Can I ask where you ordered from?
madin88 said:the point is the speed. the more speed the more energy the braking system must absorb. If you ride 70km/h and brake down very fast, a single bicycle disc will begin to fade soon and get much to hot. By this the braking system probably will get damaged too.Dual disc brake option is a good solution... Now I have one disc (very cheap) And it's not serious for the speed of my ebike!
this calculation is not right. Primarily the outer part of the rotor must absorb the heat. So its not 200g but more like 100-120g :wink:dotrick said:My top speed is 90Kph (25m/s) . The weight of my ebike and me is 100kg. The cinetic energy is e=1/2.m.v^2 = 1/2.100.25^2 = 31KJ.
The steel specific heat is about 0.5KJ/°K/Kg. If you use only the front brake, you have a rise temperature of 310°C for a 200mm rotor of 200g. It's under the maximum rating of 400°C (with an ambient temperature of 30°C).
trevc2 said:How wide is it across those 2 pelican cases + frame? Would love to see a shot from above.
madin88 said:this calculation is not right. Primarily the outer part of the rotor must absorb the heat. So its not 200g but more like 100-120g :wink:
Also the piston will get much to hot and can get leaky...
dotrick said:I think a brake system with a 200mm rotor and only 2 pistons is not enough to stop the ebike at high speed...
Let's take a look on stealth bomber (one rotor of 200mm with 6 pistons , and 8 in option ) And this ebike goes "only" to 80kph.
What is your best brake stop distance at 30mph/50kph? The braking distance for a car is under 15m.
chilledoutuk said:In my experience the handling is better at speed when you have some weight on the front wheel steering it makes the bike less twitchy because the weight dampens your steering input.
If you planning however to go off road then the weight makes quick steering inputs difficult.
madin88 said:trevc2 said:How wide is it across those 2 pelican cases + frame? Would love to see a shot from above.
i will make a pic from above. One 1200 case is about 12cm high + frame tube 4cm. Overall its about 28cm (11") wide and on bottom a bit more.
I have to spread my knees a bit but its not uncomfortable. Better this way than one heavy case at the handlebar i think..
Allex said:Let's take a look on stealth bomber (one rotor of 200mm with 6 pistons , and 8 in option ) And this ebike goes "only" to 80kph.
The 8 piston Gatorbrake from the stealth bomber is not as far as good as it looks. The Shimano Saint 4 Piston which i have is better^^ :wink: (read a few mtb threads before i ordered my braking system).
Actually, the stock Bomber comes with Magura MT2, one piston brake and they are quite good, enough for me. 8 piston brakes are marketing bullshit.
Take a look at this chart, the formula R0 with one piston delivers 124Nm in breaking power, best in the test.
http://www.bikeradar.com/mtb/gear/article/how-we-test-hydraulic-disc-brakes-24345/
No, No More you have surface more you have pressure on the rotor by the pads. Four pistons of surface S is better than two pistons of surface S/2 Take a look here It's the law of fluid mecanic. :wink:madin88 said:the number of pistons are not very meaningful. Look at hjns link! The best 203mm brake only has 2 pistons.
