safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
The Beginning
I'm at the beginning of what will be a long process to build a very unique electric bike. The frame is made of 1.5" (0.065" 16 guage) mild steel square tubes, two per leg, welded together and then ground down to smooth. I then drilled from the top down through those tubes with a 1/2" drill bit which saved about 2 lbs per leg. The current weight of the frame is roughly 17 lbs, but the seat (which will be suspended) has not been added yet. The forks shown are not the actual forks that will be used since I haven't built them yet. The "D" cell batteries will fit inside the frame. There is no head tube (the thing that the fork attaches to) since it doesn't exist in the middle of the frame and the plating around it is only 16 guage thick so the head area is both extremely strong and lightweight saving probably a pound over what a regular head tube might have weighed. (the head tube is actually two tubes that are less than an inch on each end... the 3 inches in the middle is empty)
So what you see is the COMPLETE battery pack and frame combined, since the batteries will be inside the frame. Amazing how much room there is to play with now. (and it will have 40% more battery capacity than my old SLA project) Each leg of the frame (two per side) will hold 20 "D" cell batteries which means each leg adds up to exactly 24 volts. The total battery count is 80 "D" cells and you can go either 24 volts, 48 volts, or 96 volts for your final voltage depending on how you wire them together. It will require four 24 volt chargers. (which are about $20 each)
With a 52" wheelbase... this thing is designed to go fast and never flex... 8)
It has begun...
It has begun...
