safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
The human powered speed record is 80 mph and he wasn't producing more than about 1000 watts in the sprint. It all depends on how aerodynamic the fiberglass ends up. We will see. You really start to hit a "wall" of air at about 45 mph.dirty_d said:huh? it takes like 2800W to go 50mph does it?
Don't forget I'll be in a tight tuck behind front and rear fairings... and that's when I would be running at 60 amps (1900 watts at the rear wheel) which is a lot more that I would use normally... it will heat up the motor in a hurry. 40 amps is a better heat profile for normal use. 20 amps is it's peak efficiency level.
