I have a Ninja 250 that I converted this summer. Everything is working well, but I'm struggling with the batteries. I ordered batteries directly from Headway, 80 cells to make a 40 ah pack, 20s4p. I'm charging the pack with two FMAdirect 10S balancing chargers. The charging works well. I was working on a microcontroller based LVC. It works, but as soon as the speed controller kicks in, the microcontrollers go crazy (random code execution). My controller has a LVC, but I don't have cell level LVC at the moment.
After a number of cycles, I had one group of 4p cells go to zero volts. Headway replaced those for me free of charge. A while later, I had another set of 4 go to zero. Headway didn't answer my email the second time, so I replaced those 4 cells with 19 A123 cells. This works surprisingly well, but it's expensive. I went for a ride today and in less than 10 miles, another set of 4 cells went bad. When I first started, I could get 24 miles out of a charge.
The second set to fail were on the bottom of the pack. They may have gotten too much pounding. This last set to fail are either on the top or the bottom, I'm not sure yet, I just know it's the last group in the chain from the charger.
I don't want to keep wrecking LiFePO4 cells. I'm seriously thinking of selling the remaining good LiFePO4 cells and switching to AGM batteries. I figure the AGM can take more physical abuse. I know they are heavier. I have three 24V chargers that are just waiting to charge a 72V pack.
Am I nuts? I value your opinions.
- Brad
- Brad
