CGameProgrammer said:They use threadless steerers, but the headsets (containing the ball bearings) are integrated into the head tube. Er my terminology may be slightly mixed up.
Surely adding a steering damper is addressing the issue; it slows down steering response so that it mimics that of a bike with a longer wheelbase.I just think you are wasting money on stuff that doesn't address your central issue which is the need for a custom frame
Malcolm said:...when you yourself are building a custom machine for similar speeds but have decided that there's no need for suspension. Doesn't that have significant drawbacks from the handling viewpoint?
CGameProgrammer said:Besides, normal bikes have a wheelbase between 41-45 inches. Is 52" really such a dramatic difference?
safe said:Seriously... would ANYONE out there with a flimsy short wheelbase frame and sloppy suspension risk taking a turn fully leaned over at 32+ mph?
If they do they are a little nutty... with my bike, it's no big deal...
One day I'll focus on the $$$ suspension side of things, but for now the first priorities are a long wheelbase and no flex.
knightmb said:The fastest I've taken a 90 degree turn is 35 MPH, lots of lean. It was scary the first time, but now I've done it so many times, it comes natural.
CGameProgrammer said:Well how many people drift? Certainly I don't. And I'd much rather have suspension to dampen bumps. My first electric bike was fully rigid (except the seat) and only went 34 mph, but even at 30 mph bumps and potholes hurt a bit, particularly my hands on the handlebars. Now I've a front-suspension bike and the worst bumps no longer bother my arms, though of course I wince when the 54-lb lead-acid pack in back absorbs the bumps.
agent86 said:I wonder how these would work for you, Safe?
http://www.pantourhub.com/products.html
safe said:This is an idea I'm working on right now. Maybe I might build my clipon handlebars (clipons "clip onto" the forks" directly) and normally you would have a few bolts to clamp the clipons to the fork tubes anyway, but you could add an extra plate which would isolate the clipon handle bar end with a thick piece of rubber. The bolts would first be tightened so as to make the contact to the forks rigid, then the secondary use of the bolts would be to secure the clipon handle. Or maybe two sets of bolts would be easier... I'll have to play around with the idea a little. Since I have to create the clipons anyway (well, you can buy them, but I build everything anyway and have built them before) I might as well experiment with rubber suspension.
Ironically this would tend to act like a steering dampener as well as an up and down suspension device. 8)
Toorbough ULL-Zeveigh said:That looks very similar to this piece of... old school.
