Thanks for the clarification, a lot of my planning towards a build using these motors has been based off of what you posted originally on the UK forum and also on that motor performance test table that has been posted on some of the listings for this motor on alibaba.com and I'm hoping I'll be able to at least push this motor up into the 60+ volt range to get the kind of speed I want with a front and rear double motor build. Would really like to see if it could handle the voltage of a 20s Li-Poly pack with an amp limit no less then 10-amps and not losing more then an amp or two to core heating but not so sure I'll be able to push it that far.
