AHicks said:
neptronix said:
Variable regen is a controller feature that works with any motor that can do regen.
The GMAC is not any more/less complex to deal with than a DD.
This needs to be put in a little better context, don't you think?
For starters, a DD regen will work just fine with a pretty simple/inexpensive controller and an on-off switch. That same controller, set up the same way and powering a GMAC, would have the rear tire locking up when applied.
The GMAC would require the sophistication available with a Phaserunner (and CA3) to control the regen potential from an armature turning 5 times faster than a DD, able to supply up to 90 amps of braking power. That's some serious braking I personally would want to be careful with....
Anyone trying to tell a total rookie any different is doing that rookie a dis-service - suppling bad information that could cost somebody a serious amount of time and money to find out they were fed a line of BS, intentionally, or not.....
Do you know that this is a risk for sure? the only real difference, electrically, between a DD and a geared motor is the speed which the poles alternate... and also some differences in induction values. The difference in speed itself does not create higher or lower amps.
Also, you're aware that the motor controller controls the level of regen that happens, not the motor itself? therefore, you could program your controller to take in 90 amps or much above that during regen if you wanted to, and both a DD and a MAC would cause your MOSFETs to explode. Or you could set it to a reasonable level and have it not explode.. either way, it is not the motor that determines the amount of power coming in/out in any way.
A GMAC/MAC can handle peak phase amps beyond 300A if unlimited.. if 3 phase controllers did not have current limiting then you would need a giant 36 FET controller..
A GMAC does not require a phaserunner in any way.. and in fact, a phaserunner is not entirely capable of pushing a MAC/GMAC to it's limits. You buy a phaserunner because you want all the nice features, small size, quietness, and efficiency it has. You don't buy it because it's the only controller that can handle a MAC.. which reaches saturation at 4-5kW, as i showed you guys in 2011..
