MikeSSS said:Back to watts, every ride will have a max watts and an average watts. My max watts ever was 1778, the average max watts for 23 rides totaling 720 miles is 1420 watts. .... Note: max amps ever were 32.5 amps, if the controller was reset to 40 amps max then the top speed might be higher, but there would be more chance of breaking the rear dropouts or swing arm.
Oh, you barely touched what a MAC is capable of... and you would need higher voltage to achieve top speed because you have such a slow winding. A MAC can fairly safely handle 2500w peaks without worry of mechanical failure
MikeSSS said:I'd rather have the rear GMAC rear hub motor because it uses round axles ... it uses a specific controller and the kit cost lots more than my regular MAC motor and 12 FET controller from EM3ev.
There's no need for any specific controller with the GMAC, other than a high commutation rate which a majority of controllers now have.. You could reuse your infineon clone controller from EM3ev. Just don't expect features like variable regen, the quiet drive of a FOC, linear throttle action, etc.
