if you are lucky 120MM with spacers may work. Spacers are available from most bike parts supplier. Try googling "BBSHD AND THE BIKE BRAND AND MODEL." There may be build threads out there.Hello.
I am building a new fat bike for my dad. I got the 100 mm BBSHD and when I tried to install it I got this:
Do I need the 120 mm version, right? Where can I get spacers for the left side?
Thanks.G
I don't think you're gonna be able to move the gear case far enough to the left to accommodate even the 120mm version. You'll need a shorter stack of bad ideas in one place.
search
bottom bracket spacers
Look at ElectricBike.com. The individual has reported on several conversions with a BBSHD (mostly using bikes direct bikes, but probably you can procure just a frame there or at their subsidiary, bike island).
I think you're going to need a frame that starts the widening of the chainstays farther back than the one you have, to be able to do this type of build.
Brand and model name?
Thank you!
Simplicity is the way to go!With a rear wheel motor
