After we "lost it" the walk assist doesn't work properly, i can hear the motor is trying to work but the wheel doesn't work. It's works when i pick up the bike and the wheel doesn't touch the floor.That looks huge; I don't see how it could fit in there and still let the motor run. Can you post a pic of it with the motor, for scale?
What material is it? (or what does it feel like)
There are tiny things that resemble that shape called keys that secure parts from rotating (like stator to axle, etc), but nothing that would be that huge.
If there is no key in place, the stator would rotate on the axle, or the ring gear rotate inside the shell, and the motor would not drive the wheel (or it would actually rip the wiring apart as the stator spun inside the motor).
It's feels like metal, and it's light. Someone said it's could be the speedo sensor inside wich is goes above the blue wires on the side, and we should to glue it on the top cover, but my hubby said it's too big for it.That looks huge; I don't see how it could fit in there and still let the motor run. Can you post a pic of it with the motor, for scale?
Ah okay, thank you to explain to me.The speed sensor magnets are the six little cylinders on the side cover. The actual sensor is the little hall sensor at Q4 facing the side cover on the circuit board.
If the wheel doesn't "work" meaning the motor makes sounds but doesn't mvoe the wheel, it's probably the key out of hte ring gear in the shell casing, or the planetary gear assembly on the axle.
But the image you show is so huge compared to the motor there's no way it would fit in there.
See the notch in the center of the assembly below? that takes a key like what you show to keep ti from spinning on the axle
Hello,The speed sensor magnets are the six little cylinders on the side cover. The actual sensor is the little hall sensor at Q4 facing the side cover on the circuit board.
The speed sensor is built into the motor; it's the sensor near the Q4 marking. It is triggered by the six magnets on the cover next to it when the cover is installed.BUT my PAS is gone. That was a brand new speed sensor what we used, the walking assist is works, but the Speed sensor doesn't, the LCD doesn't show the speed even when I'm just cycling on as a push bike.
Need what piece? There are many pieces in those pictures.I need that piece, either buy locally or make one.
The gears picture, the slots at 12 o'clock.
So i just tried to find out yesterday what's going on.. even i bought a throttleThe speed sensor is built into the motor; it's the sensor near the Q4 marking. It is triggered by the six magnets on the cover next to it when the cover is installed.
Are those magnets correctly working (meaning, do they attract a piece of steel, like a paperclip, etc)?
The sensor you can test, but it doesnt have anything direclty to do with PAS.
PAS is a separate sensor on your pedals. That usually has a magnet ring on the crankshaft, and a sensor mounted to the bike frame nearby. If the distance is too close or too far, it won't trigger.
Ways to test the speed sensor in the motor depend on if it's still open or if you have to test using the external connectors, and what exactly those connectors are.
If you mean the key that goes in the slot, you already have it and said you reinstalled it and it is working fine.
