CrowCreature
Hi yall, im newly registered, but definitely not new to this forum, i have been reading it since i got my ebike kit from em3ev 4 years ago and since then the motor has broken down a few times because of my own fault, which i wont go into too much, but the first repair was of changing a broken planetary gear, second time fixing a broken cable and a hall sensor.
So after fixing the broken cable and changing a hall sensor a month ago, i have a weird issue that if i demand too much power at once from the motor, like if i go full throttle from standing still, it will start spinning backwards (i presume), as i can hear the motor whiring and spining, but the wheel stands still. If i release the throttle, i can hear it winding down, followed sometimes by a clank. If i push the throttle ever so gently increasing the power, it will lock on and spin forwards and spin the wheel and if get to full speed, it will spin forwards without any interuptions, except if its not going full speed and up the hill, it will sometimes stop, make a clanking sound and start spining backwards. Usually if i go slowly and hear the initial magnet whiring sound without the wheel spining and increase the power gently from there, it starts slowly spining forwards and i can increase the throttle more rapidly to the max without problems.
Ive read that the motor can spin backwards when hall sensor/phase wires are mixed up for some reason, but i dont understand that it also spins normally with less load/torque. When i was testing it without any load, it was working completely fine.
It also could be that i messed up something when i was soldering in new cable or hall sensor, im pretty sure i soldered all the colors correctly. I also greased the clutch for better freewheeling, but somehow i dont think its the clutch slipping (or could it be?)
Tomorrow i will try to do some testing, but i really dont want to dissasemble the motor again, i tried to make it watertight with silicone and i would have to redo it and its just messy.
I will also upload some videos shortly.
Anyways, maybe someone has any ideas at least where should i start, what to check and what could cause this peculiar issue?
Many thanks
Many thanks
