My BBSHD has a very odd issue and this is coming from someone who addressed several issues in the past on several different motors.
This motor has thousands of high intensity miles on it and it is about 6 years old.
I was recently riding in wet and muddy conditions when the harness cable became unplugged and the part that is connected to the motor got a lot of mud on it. Fortunately, after plugging it back in, I was able to ride the last 8 miles without issue.
The next day I took the bike out again and after 4 miles there was a strong vibration from the motor and then the pedal assist and throttle stopped working. I fiddled with a few things but the assistance only worked again after I walked the bike backwards a few steps then immediately pressed the throttle or started pedalling. At that point both the pedal assist and throttle worked as they should until I stopped either pedalling or pressing the throttle for more then a second.
That is the current state of the motor with the exception that it sometimes works fine for a few minutes after starting it up, before it goes back into throttle and pedal assist shut down. There is an odd jerky feel when the motor is under load but I am not so sure that wasn't there before.
I have disassembled the front plate of the motor and the gears looks properly greased. I have cleaned the harness wire with isopropyl alcohol the best I could but it goes right back into this state of occasional shutdown soon after.
My guess is that it could be a hall sensor issue or a harness wire issue, but I would like to try and eliminate all the easy possibilities before investing time and money into those more complex avenues.
