okmatey
100 mW
Super,thanks so much its starting to make sense now, any suggestions on a second controller ??
This is good stuff,so if you would suggest a second controller what would you choose? Or should I say what's the cheapest option ?The easiest way to build a two motor bike, in my opinion having done it this way, is to run the second controller with no display and throttle only. The other controller has throttle and pedal assist. It's possible to run both controllers off one throttle too.
A Frankenrunner if its still available, or a Phaserunner would be absolutely awesome.any suggestions on a second controller ??
Obviously I will order what I need from a supplier in the UK, so I will have a look this evening, I will be back soon, your information is genius thanks so much,oh just before I go, what motor should be rigged up to the existing controller ?A Frankenrunner if its still available, or a Phaserunner would be absolutely awesome.
.....Oh you probably meant cheap, most likely, better buy one that lots of people have bought from and has had great success with, better buy one that has good documentation, better buy one that has a picture of the wires and their names, might be the proper picture but might not be, which is why one would buy one from a place that others have purchased from frequently and has had little problems with in terms of returning or receiving damaged items or recieving the wrong item. You'd want a known entity I'd believe, a place that sells lots of quantity of product, a place that sells only ebike stuff. PSW Power is good for your displays and such, Greentime is good because they have plenty of ebike stuff to browse through.
Super info thankyouIt’s a DC Moto controller by Lithium Battery. There are plenty of photographs showing the cable connections, especially on Ali Express. But all of the ones I have seen show white and black for the low brake cut offs. Yours are red and black so be careful with those because as stated they may be lights instead and you don’t want to short out the supply otherwise you will blow the 5v regulator. So use a multimeter to check the voltage between red and black before connecting anything to them.
They are most likely low brakes as stated on the label.
It is a 26 amp controller so:
26 amps x 36 volts = 936 watts
26 amps x 48 volts = 1248 watts
So it’s capable of running a 1000 watt motor, but be aware that UK regulations mean that a motor rated at over 250 watts is illegal and we also have a ridiculous rule about throttles only allowing 6km per hour before peddling and then motor assistance has to cut out at 15.5 mph.
In reality this means that your motor should be engraved with 250 watts and the controller must be configured for it to cut out at 15.5 mph and the throttle needs to activate as said above for it to be uk compliant.
Not many self builds comply to these regulations in the UK. But KT controllers have the ability to be configured for UK compliance if you wish to do so.
1. I wouldn't use a battery pack of unknown condition or originHi guys,I've a few questions I hope you can assist with,I've been doing the mechanical side at the minute and now are ready for the electrical side.
1.The battery I have is rather battered and I really don't know what voltage it is as I haven't got a charger, is it worth tidying it up and using it for 1 controller ?
2.will 1 battery be OK for 2 motors?
3. What's the best setup for 2 motors, will a £40 controller do the job with my other controller ?
4. I've looked everywhere on the front wheel hub and can only see the numbers haven't a clue what wattage it is
Thanks guys
The plugs on the 2 motors are the same, but was concerned it may be 36v and not 48v is there a way to check the ohms of the wiring ?When you're working with no-name cheap generic stuff like that, you really don't have to know its identity. What matters is whether the plugs are compatible with the new components you would like to bring in. If they're not, then you have to reconcile the motor cable with the controller. Once it's testable, then you can find out the RPM/volt and assess for yourself whether the two motors can work together effectively.
With an expensive ohmmeter, you could check the wire resistance. But you don't need to. The plugs are far more significant to resistance and heating, and the affected lengths of wire are short.The plugs on the 2 motors are the same, but was concerned it may be 36v and not 48v is there a way to check the ohms of the wiring ?
Phase current is AC, transmits with fewer losses, ie, doesn't heat up the cabling as much. Which isn't to say that thicker wire wouldn't be better. But then you have a bit more difficulty running it through the axle if the wires are thicker. In addition, mass-producing manufacturers run the thinnest wire they can get away with, for cost reasons.I used to be offended by how skinny most hub motor phase wires are, given that they are asked to carry up to 2X the current of the battery cables. But in practice they all seem to work fine even at currents well in excess of the motors' ratings.
That's assuming all controller's measure their current ratings the same way. Which they don't. Most of them have their rating based on max allowed battery current. But If I remember correctly, Kelly likes to rate their controllers based on max possible phase current, short term rather than continuous. Cuz bigger numbers.Would each phase current in a BLDC be like 1/3 of the controller's max current?
