I've been planning to start my controller thread for a long time, now here it is. It's about my latest build that I made for development and testing purpose, started sometime in the spring last year and still in progress.
It was designed to fit in the hammond 1590U or the gainta G0474 box (almost the same, external dimensions: 120x120x59mm):
https://eu.mouser.com/ProductDetail/Hammond-Manufacturing/1590U?qs=lxPAlgZqN%2FxeTOQJUYeowQ==
https://www.tme.eu/hu/en/details/alu-g0474/multipurpose-enclosures/gainta/g-0474/
The circuit consists of 3 boards stacked: power, gate driver and CPU. I planned this way to make it easier to change to another gate driver or CPU board without redesigning the whole unit.
I made the design in an older software (Accel), so instead of the source files I just share pdf and screenshots. No spectacular 3D views.
The schematics are 3 pages, each for one board:
View attachment 10kW BLDC motor controller sch rev01.pdf
PCB drawings:
all boards top
all boards bottom
power board bottom
power board top
power board output nodes in magenta (cut from 0.5mm copper sheet and soldered on the top layer with thin insulation boards above +VBAT (white rectangles in the middle))
snubber modules (small PCB-s soldered between the MOSFET legs)
driver board top
driver board bottom
CPU board top
CPU board bottom
Originally I started to design this controller for this bike (dark green box inside the frame on the bottom plate):
But I'm not going to build this frame in the near future, so I will install it on my current bike.
The gate driver circuit is a bit more complex than usual because I wanted to adjust all phases of the MOSFET switching transients separately as much as possible, such as the Vgs rise and fall times, length of the Miller-plateau (Vds edges), length of the current transients for both the turn-on and turn-off, and the high frequency oscillations.
I'm using this controller also to develop my FOC firmware with full torque sensorless start, that is also in progress.
So at the moment I'm building only a single unit for development purposes, maybe later I'll design a simplified version for sale with only 2 boards.
The boards are already built and mostly tested, I will post photos and waveforms later.
Some resistors/capacitors on the schematics may still change.
PCB drawings:
all boards top
all boards bottom
power board bottom
power board top
driver board top
driver board bottom
CPU board top
CPU board bottom
