jdcburg
Hello - I am new here and am just starting an ebike build. I will be using 24 volt sla power pack (2 12 v 12 ah in series). I may step up soon to a Li pack, so I am thinking about using a 12 volt 5 amp charger I already have, rather than purchasing a 24 v charger that probably won't be optimal for a Li battery. Can I just switch the jumper(s) to make the batteries parallel/12 volts and hook up the 12 v charger, or should I disconnect them and charge them individually? I did a search of the archives and didn't find the answer to this question, although I may have asked it incorrectly. Thanks - jd
