gothicsurf
The goal of this build is a bike that is efficient on the hills but also has a decent top speed. I am currently working with a minimal Bafang SWXK front motor which is just barely enough assist to make it back home fully loaded. The next step is to add a trailer weight of roughly 50lbs and for this will be adding a second motor.
The battery is also fairly minimal at 17Ah and 36V so would like to add as little weight as possible. I am hopeful that another minimal geared motor would be sufficient but also want to do better than just barely there. I have been considering a 500-1000W DD motor yet my climbing speeds may be in the 15mph range.
The compromise might be a more powerful geared motor. The elevation profile of my commute is attached showing the 1000ft climb one way. Regen would not be a major advantage because the downhill would be with a full charge.
