60A charger for 48 volt battery
This website have some high current chargers like QW481-600-L:
AC 220V Factory Direct Sale DC 54.6V 60a 3600W charger for 13S 46.8V 48.1V Li-ion/Lithium Polymer battery
Model Number:QW481-600-L
Output current:60a(Max)
Brand Name:QUAWIN
Min. Order: 100PCS
Output power:3276W
Weight: 8000g(only body)
Dimensions (mm): 315*180*90
I guess someone must be using them but what batteries/vehicles are they used for?
Would be so cool having a battery that can accept 60A and fully charge the battery in 30 minutes or how ever long it takes.
For this purpose I would look for a Huawei R4850 (3kW) or R4875 (4kW) or an Eltek Flatpack 2 48/3000 He.
Both around 2kg and size for the Huawei 42x109x285mm and the Eltek 42x109x327mm .
Efficieny around 96% and only one 40mm fan inside.
I can charge up to 5kA... but rarely do I charge harder than about 300Amps for pack acceptance rates.
Ones with high Ah capacities.
It is easy to damage, even destroy a pack by feeding too high a current, start big fires too.
Stay at 0.4C to get best longevity, lower in cold weather.
1C is the limit on many spec sheets for li-ion, but only in warm ambients.
Racers sometimes pre-heat the packs to get high rates without damage.
LTO is an exception, can get back to Full in 10-12min at 25°C
but it is too bulky & heavy for most propulsion use cases.
For House banks in a yacht, RV or off grid cabin, that 3000W unit would be just fine for even a small bank of 150Ah, but most are at 12V or 24V rarely 48V.
800Ah even 1500Ah is normal for a big setup, so chargers like that may get paralleled if suitable AC power is available.
