EZgo
1 W
A FINAL PUZZEL FOR 2021!
Is it possible for a direct drive 2013 9C hub motor to run fine at 48 volts but not on 72 volts? (jerks/vibrates forward or backward) Please read below.
This bike has run better than perfect for me for 3 yrs. at 72 volts through a 100amp Lynn Extreme Controller & a V3 CA . Then a medical issue kept me from riding for 4 yrs. & the bike sat. Three months ago I installed a new 72V battery & started riding again. Once again it ran perfectly for 2 weeks. I put it away after a 5 mile run one night & got it out the next day. It would not run.
The bike itself was originally built using a 2015 48V kit from ebikekit.com. It's a 1000 Watt direct drive 9C hub motor. I soon thereafter modified it with a 72 volt Samsung battery from Luna Cycle a V3 Cycle Analyst & a 100 amp Lynn Controller setup for 72V. Lynn built the controller for me and installed the necessary plug ends so that I did not have to do anything other than plug it in to my 72 volt battery and my ebikekit.com wiring.
The bike ran perfectly for about 3 years until my medical issue knock me out of the game.
It sat for about 4 years until three months ago when I put it back into service with a brand new 72 volt Samsung battery. The new battery uses the Samsung 21700 4000mAh 30A Cells which is tiny bit hotter than the old samsung18650 cells. I have never run this bike hard save for a few top speed runs. Here are the symptoms & my troubleshooting methods:
With the rear wheel off the ground when I give it throttle it jerks (vibrates) forward and or backwards depending on its mood.
I trouble shot this issue by first ruling out the throttle, then any wiring connections and then the V3 Cycle Analyst unit.(I bypassed the V3 & plugged the throttle directly into the controller getting the same result) Grin in Vancouver helped me to rule out any other possible Cycle Analyst issues. I have also installed a new twist grip throttle even though the old throttle worked fine. (just to be sure)
That left me with the Lynn controller or a phase wire issue with the direct drive hub motor. I eliminated the hub motor by parking my wife's 48 volt ebike next to mine & connecting her ebikekit.com plug (same vintage) directly into my hub motor plug. I used her 48v battery, throttle, her wiring & her original 48 volt ebikekit.com controller. My motor ran fine even under load.
Lynn has tested his controller for me as of 12/29 & said it works fine although he did this using 48 volts. I have since emailed him back to see if he could test it at 72V.
I've been a mechanic for 30yrs, a DC floor machine tech for 10yrs & an ebikekit.com dealer since 2012. I'm not a ebike expert but I do know how to trouble shoot & isolate faulty components.
I would greatly appreciate and welcome any suggestions, Ideas, thoughts or comments as I am fresh out of ideas. THANKS & HAVE A GREAT 2022!
