Seya
- Joined
- Feb 27, 2012
- Messages
- 81
I just replaced all three hall sensors and the whole wiring harness.
Multimeter readings ( from the leads on the sensors themselves )
Are the following:
Yellow stays at 4.9v
Blue stays at 1.8v
Green alternates betweem 0 and 5v as wheel spins so it works fine.
The yellow and the blue arent working. These are brand new honeywell sensors.
I know my soldering is sloppy and you can see the glue was also not so pretty I'm doubting this is causing the problem.
As you can see in the picture the yellow Hall sensor is not in all the way. But it is reading a continuous 4.9 V. i don't understand things enough to know where to look next??
Any thoughts?
Are the following:
Blue stays at 1.8v
Any thoughts?
