ok, at this moment I'm using a 48v 10ah(30a bms) battery in parallel using a combiner with a 48v 20ah(30a bms) on a single motor ebike and it works perfectly. I have a second ebike with dual motors which has a 48v 23ah(50a bms) battery and utilizes two controllers@25amps each. Can I use the 48v 10ah(30a bms) battery with a 50a combiner to add capacity to the system with no issues even though that smaller battery has a lower rated 30a bms?
