Thanks for replying. I am not looking for high speed, but high torque is super important. I live on a very steep hill, steeper than what most thing of when steep hill is mentioned and my last ebike could not make it up the hill without me doing some very vigorous paddling- about the same as with a non motored bike. Otherwise low speed is fine but i sure do not want to overheat the motor- how do i keep it at a speed it can easily handle? Thanks for the heads up about that for a question i didn't know to ask.Spoke it to a wheel first.
Do note that this is either a MAC or BMC.. these have poor efficiency in a 16" scooter wheel, aka 20" in bike tire size. The high pole count makes them unsuitable for a wheel smaller than that. The result will be that the motor overheats on the flats.
Consider using a wheel designed for the higher RPM a scooter runs at instead.
A small direct drive hub would be the optimal motor for a scooter... in terms of max efficiency and max power.
I would install a temperature monitor. Since it's a geared hub, it won't be able to shed excess heat easily, so depending on how long the hill is, you'd want to stop to let the motor cool if it starts to overheat.Thanks for replying. I am not looking for high speed, but high torque is super important. I live on a very steep hill, steeper than what most thing of when steep hill is mentioned and my last ebike could not make it up the hill without me doing some very vigorous paddling- about the same as with a non motored bike. Otherwise low speed is fine but i sure do not want to overheat the motor- how do i keep it at a speed it can easily handle? Thanks for the heads up about that for a question i didn't know to ask.
What would be the best way to put a pneumatic tire on it? The flange holes are for bike wheel spokes
A custom fabricated adapter attached to the flange's spoke holes where that adapter is the rim/rim bead the new tire sits on.What would be the best way to put a pneumatic tire on it?
I have a BMC HPC Black Lightning hub motor that i want to use for my e-scooter.
