I'm looking into seeing if a triangle battery case is something I can put together, and I'm probably going to be limited to using hand tools.
Features I'm looking for are:
The plan so far is:
Things I'm not sure how to go about at all:
Are there any problems you can see with the plan so far? Any tips on how to go about the features that haven't got a plan at all?
Thanks in advance!
- Accommodate ~ 15kg
- Secured to frame as much as possible for public parking
- Hinged access panel with lock
- Weather resistant
- Accommodate 26650 or 32700 cells
- Power for tsdz2 motor
The plan so far is:
- Prototype the shape out of cardboard
- Cut a frame from 1.5(?)mm square aluminium tube with a hacksaw
- Join the square tubing with strips of aluminium sheet by using a rivet gun
- Cut some 1.6(?)mm aluminium sheet to the shape of the frame
- Rivet the aluminium sheet on to the square tubing frame with a rivet gun
- Seal the inside with silicone
- Constructing a hinged panel, and making sure it doesn't rattle from vibration
- Adding a lock to the hinged panel, and making sure it doesn't rattle / come loose from vibration
- Water sealing the hinged panel
- Attaching the case to the frame so that it's at least difficult for potential thieves to remove
Thanks in advance!
