bandaro
So, just chucking the idea out there, but if one was to run a lower voltage/lower kv motor than i have seen, then they could fit the motor above the kickstand mount right in tight to the bb, and have a gear made with say 5 teeth or so that would fit directly onto the regular chain sprockets. so the gear will need to be made to be a chain basically, but a chain fixed in a ring and bearing on the teeth etc to reduce friction on the gear. that way you can leave the bike unmodified (assuming the motor fits in front of the rear wheel there) and have the full range of gears you normally would. then it would be simply add a freewheeling set of cranks and your set. the drive would essentially run the unused half of the gears not interfering with the chain in any way.
so what do you guys think, would it be a viable option for decent powered systems? or would it be too hard/expensive to make a pinion that would fit as a chain would but only contacting 2 teeth at a time? i can make up a cad of this if anyone is still unsure of this idea, its just off my head atm.
