The PP30 are really nice if used with 10AWG.
They take 40A continuous no prob without overheat. It's tricky to insert all the strands for 10AWG, but if you enlarge a bit the connector ansd than crimp it with the right tool and solder it at the junction of strands input and the connector input, it's perfect.
I'm using PP30 for all my ebikes onthe phase wires since 2007 and often see current over 250A burst on the calibrated C-A and the connector never get hot.
If you take a look of the pp30 spec sheet, you will discover that the temperature of the connector and ( as well his current limit) is relative to the temp and the size of the wire. The conector evacuate the heat thru the wire strands so bigger is better.
The difference of power lost from a very big pp75 and a pp30 is negligible.
pp30 is 0.6 milliohms and the pp75 is 0.2 milliohm
the difference is 0.4 miliohm
at 100A, wich is burst it's 4Watts during the burst
for 40A continuous, it's 0.64W continuous per wire
2 wire at a time is .... 1.28W average :lol:
I guess that due to the big size of the pp75, the air friction due to the added surface area catching more wind ... generate drag that draw more power than 1.28W you could save using pp75 :lol: :lol: :wink:
That's my oppinion, but you decide :wink:
Doc
