AussieJester
1 TW
tritonwow said:Do you know if this show airs on the internet for those of us without Aussie TV?
I dunno..i recorded the last one Carvin Marvins (tilting trike) and upped it too youtube, will do the same for Keplers.
KiM
boostjuice said:
rodgah said:hey kepler been watching for a while now,
I like the concept its always great to see something that isnt a hub :wink: .
As refers to waterjet vs laser, laser in theory/generally should be atleast 1/3 the price of water due to complexity and speed of cut between the 2, this depends alot on type of material though.
*warning kim...science lesson*
Even though aluminium is weaker than steel, biz, titanium for that matter it is almost twice as hard to cut with a laser because instead of absorbing all of the light energy(leading it to vapourise) it instead reflects a decent percentage back, sometimes as much as 50%, same with stainless to a lesser extent. For example on a 5KW CO2 laser you can easily cut 20mm mild or high carbon steel, but you are really struggling to cut 5-6mm aluminum even with >300psi of high pressure nitrogen, and maybe 12mm 304 or 316. Copper is almost completely reflective, it is used as mirrors inside of a laser to bounce the light around and down to the head and to the material.
A water jet takes a hell of alot longer to setup, and cut say a piece of 12mm black than a laser would, hence a laser is more cost effective, but give a laser a piece of 120mm aluminum and you will have alot of work ahead of you replacing mirrors and lenses due to reflection....oh and it wont cut lol. But a WJ will just chew away at it till its done.
Another option is High Density plasma cut. In most circumstances a laser is just way too much over kill on precision for what is really needed ( i dont really know in keplers case since i cant see an exploded diagram). People have a little wank over it being cnc laser cut when in real life a monkey with a file could have made a perfectly usable part. HD plasma kills in speed on most things, at the expense to a bit of precision. If you havnt had a quote done yet, I would look into it kepler, you might find it very different.
Im all for using higher strength plastic for things like you have already done kepler. Is it HDPE?? very very durable. Cuts like butter on a laser, up to 10mm even a very modest (low power) laser could cut at about 4-5m/min.......making 1 part might take 20secs to do including traversing, it works out very cheap, most work is done around the $200-300 / hour mark of machine time.
Hope it all works out for you though kepler,
Cheers
Kepler said:Where did you read that? How can a show posted on the internet not be available to anyone in the world to view?
spinningmagnets said:Gotta be a way to "You Tube" the show so the rest of us can get a glimpse !!
First post on this thread was February 26, 2010, roughly 4-1/2 months ago? Kepler, soon you'll be on TV and in magazines !
Kepler said:rodgah said:hey kepler been watching for a while now,
Cheers
Thanks for the info and advice. I presume this is a type of business you have been involved with professionally. Laser cutting is reasonably economical for what i am doing and having the precision ensures the mated edges give little chance of moisture entering the electronics compartments.
I will investigate the HDPE. Do you know if it comes in a gloss or satin finish? Done quite a bit of prototpying with Acrylic using the 4.5mm thick sheet. Dispite a bit of negitive comment on this product, it sure has proven to be more then strong enough and provides a great finish. Very cheap to cut also as you know.(just expensive to buy)
Sticking with Aluminium for now but will continue to test the viability of these other options.
Kepler said:No wonder the garden is overgrown and jobs around the house are backing up. Got to have your priorities though(ebiking )
rodgah said:Yeah everything from maintaining lasers, programming for them, operating them, and the business side of things. Every day was a struggle to keep a constant work flow because plasma and water are 2 very good alternatives, just depends on what you need to cut. Typically (depending on how lazy the operator is) you can get a tolerances smaller than 0.05mm on a laser, and around 0.5mm on a plasma. Appart from that the parts look identical, cut finish is very much the same, same amount of divergence etc. Keep in mind, cut hole diameters usually cant be smaller than the thickness of the plate, and cutting on both types usually hardens the surface a bit making it hard to tap. Some places offer drilling and tapping aswell, just depends on the machine.
cheers.
AussieJester said:Kepler said:No wonder the garden is overgrown and jobs around the house are backing up. Got to have your priorities though(ebiking )
Sheesh man ... you haven't got the ole' ball and chain very well trained, best get onto her about those lawns and odd jobs mate you have better things to do than wiminez work damnzit!!! :lol:
KiM
Kepler said:I dont want to push my luck too hard. Little matter of having 11 year old tripplets to take care of too :lol:
Kepler said:Wow, gorgeous looking girls. 2 of my 3 are girls too. Scary
Kepler said:know the one you mean. It was a good design for the 90's but probably held back by technology. I think evtodd's thread has a bit on it. It used either one or two brushed motors with a roller in the centre. Don’t know how many different types of bikes you could get to fit but was a commendable setup all the same.
bandaro said:so be sure to tell us when the show is airing keppler, ill watch it for sure, assuming it airs in canberra...
so how long until you are ready to roll out some systems? i found an old racing bike in the garage from previous housemates, just fixed it up to sell, and thinking i could get a system from you, test it out, then sell the bike as electric bike and it wouldnt cost me a thing a professional, Australian designed system fully mounted on a bike ready to go, as seen on TV!!! already have some batts ordered that i will not be using, so i might not cancel that order and chuck em in with this bike...
you got a price on the system yet, or not until the parts are cut? also, what voltage does it run?
sk8norcal said:found it !
chronos hammer
in this power biking article from PM 1995!
http://books.google.com/books?id=NGYEAAAAMBAJ&pg=PA48&lpg=PA48&dq=chronos+hammer&source=bl&ots=o6L8V6LD3t&sig=5TAzOQFGm4H3-HvS9fJ4ZlupGtU&hl=en&ei=l8Q9TP3mL4PQsAO855zaCg&sa=X&oi=book_result&ct=result&resnum=9&ved=0CDwQ6AEwCA#v=onepage&q=chronos%20hammer&f=false
If I get any closer to the edge of my seat... I'll be sitting on the floor! :wink:Kepler said:I can tell you it will be priced to be an easy decision to buy.
