Had a few requests in relation to fitting the larger 63mm Hobby City style motors so I thought i better include this as part of the testing process.
Fitted a Turnigy 63-74 200kv motor. This motor is rated at 3000W and nearly a kg in weight. I needed to make slightly longer pivot plate to allow the motor to clear the main body and fitted a longer pivot shaft also. This motor really is too long for the drive but i was more interested in seeing how well the drive coped with the larger diameter, weight and potential power.
Results were mixed but did show the bigger diameter motor was a viable option. 200kv even on 6S is a bit low for outright speed and I am tipping anyone going down the big motor path will be looking for some decent top speed. This setup on 6S was good for 30kph and as expected, lost very little speed up moderate hills.
The major negative was that low speed pickup quickly saw some sync issues creeping in. It seems the larger diam motor requires more torque on startup hence higher amps at that critical low throttle setting. Not ideal but not too hard to ride around for those who want to use this motor.
48mm diam motor is still a better choice. I really want to test the Scopion but I cant get one for another 2 weeks
