MikeSSS
An alternative to torque or rpm pedal assist is to use the cruise control on a Cycle Analyst V3. Throttle along with CA V3 cruise control works very well. The only pedal assists I've liked have been on the Bosch torque sensor mid drive Trek bikes and the Bafang Ultra torque sensor mid drive. Bosch doesn't have a throttle and so it's hard for me to get started on an uphill. Bafang's Ultra is easy to get started on an uphill because of the throttle and the throttle and the torque pedal assist work well together.
I set my CA V3 cruise to start after 2 seconds of constant speed. After the cruise is set, I pedal with the effort that is comfortable or desired. Speed will decrease when climbing, so I downshift to keep cadence. Speed will increase on descents, so I upshift to keep cadence, or coast with cruise on, or turn off the cruise and pedal or coast. Shifting does not change the cruise setting. Also there is a visual on the CA display that shows you if cruise can be set and what level of cruise you will get or what level you are in. Speed in cruise can be as slow as perhaps 1/3 mph, when walking the bike up something steep and difficult, up to a high cruising speed.
Cruise disconnect is done by advancing the throttle a bit but not to the point of adding power, or advancing the throttle to add some power, or by tapping the brake levers, or by using the brakes.
CA V3 has three throttle modes: Pass Thru, Current and Power, these are also known as Pass Thru, Amps and Watts. Cruise works best in the Pass Thru mode.
Before getting the CA V3 I thought cruise was probably a bad idea, I was wrong. Yesterday I rode 34.2 miles, probably 34 of that was in cruise. Pedal effort in cruise ranged from coasting to pedaling hard when that felt good. ETA: I probably pedaled 34 miles out of that 34.2. Pedaled while using cruise.
Hope this helps somebody.
